Hi Paul,
You can get strange behavior sometimes with the sweep 1 rail, as with your example, it looks like the sweep is being made on the center of the arc, I have seen similar, and also times where such a sweep will invert and be made inside the sweep rail.
Normally on such a 1 rail sweep I will set the profile to a control point/intersection on the rail which then usually works correctly
- manz
