Make Surface
1665.22 In reply to 1665.21
You should be able to create the surface in other applications even poly apps, for example, I created the surface in Hexagon from the line data (the other poly programs would not import the line data, so did not attempt).
In MoI/Rhino you would build using "network", in poly programs you would use (as in Hexagon) "Gordon surface". I am not saying the resulting surface would be accurate enough for machining, but it can be easily modeled from the curves given.
- manz
