You must be cautious to use Network for this type of surface. When input curves are G1, the resulting surface might seem OK and will be valid. BUT there is usually a problem with the surface normal at the corners. Try to Offset the surface and see what happens... If you're not planning any downstream operations that will confilct with this (shelling, fillets, etc) then it probably won't be a big deal...
jonah
