Make Surface
1665.12 In reply to 1665.10
Hi Paul,
>>I say good because if you turn the surface and look end on there is a crease when the surface again meets at a point.
What did you use to check the surface? If you are just looking at the model in MoI then you may just be seeing an error in the created mesh not the actual surface.
- manz
