Hi Kreten, thank you very much! :)
Typically it works very easily to export data from MoI to Cinema4D - just use OBJ format and normally that works great for getting models built in MoI into C4D for rendering.
You usually don't have to really even mess with any settings, unless you want some special effects like animating the model in certain ways like bending or twisting it - for that you'll want to mess with some settings for dicing up polygons into smaller bits instead of having large polygons.
But if the animation you are talking about is like camera animation and the object itself does not morph, then you don't have to worry about that.
