Hi Danny,
> could we then use that planar surface as a sort of datum plane to
> draw on with this new "On Surface" command ?
Yup, that will definitely work - it will be kind of a basic way to set up a drawing plane.
You actually don't have to create a rectangle first and then make a plane second, you can create the plane all in one step by using Draw solid / Plane.
