Drawing on surfaces
1621.12 In reply to 1621.10
>>It will be the surface that is being displayed at that point, so the one most to the front.
>>Again this is very straightforward - it snaps to the object that you can see that is under your mouse, there isn't much mystery about it.
But that is how I would expect it to work now for snapping onto the edge of a cube in 2d view,.. but it does not, the snap changes from front to back (or top to bottom depending on 2d view) as you move around the edge.
>>When you run into that problem with "on", the solution is generally to switch to the 3D view so you can more easily target one particular edge with your mouse
I think it strange to have to go to 3d view to be able to correctly create a planer(2d) curve via snapping.
- manz
