Hi PaQ,
> Is it possible then to use this 'on surface snaping' to drag
> and align objects over a surface nornal ?
Not really by itself yet - it is basically something that assists commands that pick points.
I do want to make a set of orientation commands which would be focused on doing that (moving an existing object to align with a surface normal), and certainly this snap will be a part of how some of those commands will work.
However, this new snap should allow for drawing brand new objects aligned to a surface normal right from the beginning, once I get the normal-line straight snap working.
