NGon WIP
162.57 In reply to 162.56
> another thing very handy would be if we can export each object group
> with a different poly amount setting, I had an nice spanish chair where I
> needed more details in the seat part and when I added it there the frame
> was going insanly detailed and boosting the object from 8k polys to 50k polys.
This should be improved quite a large amount with the new meshing system as well - it's actually what I've been working on most recently.
With the new system, the density will increase much more gradually. When you want to add a little bit more detail it shouldn't increase in such large jumps elsewhere as the current beta does.
So this should hopefully reduce the need to set a bunch of different settings per object. But we'll see, when the new beta is available let me know if you still run into situations where it is a problem.
If you happen to have that spanish chair handy, if you post it I can give it a test.
> It would be nice to have some kind of material setting like just colours and
> maybe transparency :-D
Yup, this will happen eventually. I'm not sure exactly when.
