Hi Pierre, can you please show an example of what you mean?
The way it works right now should give you perpendicular object copies already, as long as your initial one starts out perpendicular as well.
For example, starting with this shape which is arranged to be perpendicular to the curve:
After performing array along curve, each of the copied objects will also be perpendicular:
