photoshop CS 3
1601.2 In reply to 1601.1
Hi Steve, do you mean that the objects are oriented in the wrong direction?
If that is the problem, please try changing the setting under Options / Import/Export / OBJ options / Orientation, and see if that works better for you.
If you are having worse problems than that, you might try un-checking the "Weld vertices along edges" box in the meshing options dialog when you export from MoI. You have to push the little arrow in the lower left corner of the dialog to expand it to see this option. That will export an .obj file that has a somewhat more simple structure, maybe it will work better with Photoshop.
