Hi Michael
I was wondering if it would be possible to add a 3D-Mirror option in order to create a copy of an object using a plane or any 3-points in space?
The attached shows the current process, following a two step-process. Starting from the lower-left to the bottom right, first create a mirrored copy and then, on the top-right, another copy via rotate-by-axis. I believe a 3D-Mirror would cut down on the steps, unless there's something already there I don't know about.
Cheers,
- Diego -
