Hi billis,
> in rhino.but this i say is litle diferent that urs tutorial.the command
> i say make a object folow a curve
Yes - the command in Rhino is different, the steps that I showed above were for creating that kind of effect in MoI.
In Rhino try using the "Flow" to warp an object to follow a curve, or "FlowAlongSrf" to warp an object to follow along a surface.
Since this is the MoI support forum and not the Rhino support forum, this isn't really the right place to go into a bunch of details on how that Rhino command works, you might want to ask in the Rhino newsgroup for more help on that Rhino command. But I hope giving you the Rhino command name may point you in the right direction - try starting with the Rhino help file.
> (if this command there is and in moi i wana learn it)
No, sorry, MoI does not have that command. In MoI you would need to use the steps that I showed previously - trim a surface and then move surface control points around. But that is definitely more steps than Rhino's Flow or FlowAlongSrf methods, so I would recommend using Rhino for this instead if you have it available.
