adjusting the camera's lens length
1585.6 In reply to 1585.5
It's usually not a big deal unless you have long objects which extend deep into the background. Then the difference becomes quite noticable. Also, it's best to model with the same lens as will be used for your render, especially if you are designing from a perspective image/sketch or you're planning to composite into an existing image.
jonah
