MoI License
1580.5 In reply to 1580.3
Hi Paul,
you wrote:
> Cool!. What is the size of MoI when installed on a stick ?.
Just 16 MB. That's actually including documentation, you can slim it down by 3MB less if you don't include the \docs folder.
> So did you run an installation with the target as the memory
> stick or how did you do it please.
Actually, all you do is do a normal install on your regular machine, then just copy the "C:\Program Files\MoI 1.0" folder over to a folder on your USB stick.
You can actually run the MoI.exe program directly off that USB stick when you go to another computer.
To bring over your settings, you need to copy over the moi.ini file which is in a slightly different location, also to avoid getting prompted for your license key you can also copy over the moi_v1_license.key file as well, some details on that here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1284.40
