MoI License
1580.4 In reply to 1580.2
you wrote:
> You can put your code into a Word Pad document on the memory
> stick then cut and paste it when MoI prompts you to.
Actually if you want to bring it on a USB key with you, then also copy over the moi_v1_license.key file and you won't even have to do any copying and pasting.
When MoI starts up, it will check for that moi_v1_license.key file in the same folder as moi.exe is in, and if it finds it it will use that information and not prompt you.
Also if you want to bring along any customized settings, copy the moi.ini file over to the same folder, it works in a similar way.
Some more detailed instructions here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1284.40
