Hi Petr,
> Perhaps, the pivot icon size could be decreased slightly...
Yup, probably will feel a bit less clunky that way. How about this:
I've gotten more used to the slight smaller corner icons too, I think I will keep those but have the original slightly larger one for the highlighted state.
> Does it mean that when you drag a grip and want to use a "snap to grid"
> feature, then the snap action actually occurs under an imaginary point
> (corner of bounding box adjacent to the dragged grip) and not under
> the grip?
Yup, the grip is actually slightly to the outside of the actual point that you place when you drag it.
Dragging it is not so much actually placing the corner as it is placing the edge of the new bounding box, since it does a uniform scale (this is the same way that images work in 1.0).
