Hi Will,
> Yes, it was already determined that Illy uses a seperate
> command for the rotate etc., not all graphics apps do that however...
Actually, Illustrator does allow for scaling and rotating from selection mode without using those special tools. But the dedicated tools allow setting the origin point which you can't do using the quick bounding box grips.
