| Hi Brian,
 Starting to look good.
 >>>The Obj file from that 58.3MB
 You would be better to change settings or format used.
 When I was outputting the bot model, I did play around with the settings/ format.
 Examples.
 I used a default of 3 deg for mesh output. That gave an obj output filesize of 203mb
 I then changed setting to "avoid smaller than 0.5. That then made the obj filesize 14.66mb
 I changed format to LWO, that (with avoid smaller than .5) gave LWO filesize of 8.266mb
 I then output via 3DS (with avoid smaller than .5) that gave output 3DS filesize of 2.764mb
 For Carrara, it did handle each file well, and the render did not suffer.
 - Steve
