It was different at first, but I assigned it to hotkey and that made it almost as fast as a widget. Plus it has alot more versatility with being able to quickly set a custom pivot relative to things around it, rather than resetting a hotpoint away from object center. If you know the angle you want then just hit rotate, select pivot, type the angle and hit enter.
