Hi Brian, it definitely can be a problem. What you describe is an interesting idea, but at the same time I do kind of worry a bit about clearing the selection too easily, because accidentally losing a selection that you have carefully built up can then be a different kind of problem.
Sometimes when you run across this problem one other way to solve it is to hide some of the objects so that there isn't so much stuff on the screen all at once.
