Cinch plug
1545.2 In reply to 1545.1
Hi sayd,
you wrote:
> All went well during the model except for some small problems. So
> i had to do some things different that should have worked the same
> in MoI as it would in Rhino. For example the lofting of the circles.
> I could loft all of the at the same time.
Could you please describe a little bit more about the circle lofting problem that you ran into?
If you could post a .3dm model file that shows the problem, it would help to clarify it for me. Maybe there is a solution to it using an option in MoI that works slightly differently than Rhino, or maybe it is a bug that I need to fix up.
re: rendering - I don't think your render looks too bad. But lighting is one of the toughest things to set up for a good rendering. It is a pretty big subject, here is a book on it: http://www.3drender.com/light/index.html .
