Hi Tony, also one of the things I'm trying to set up for V3 is to have the controls to be more based on parameters declared in CSS with stuff like gradients and rounded corners (which works with WebKit's HTML engine) and not as much based only on image backgrounds.
It should make it easier to tweak colors because a lot of them will be controlled by declared rgb values.
