Circular Helix Array
1519.16 In reply to 1519.15
Hi Brian, you're welcome, I'm glad you are having fun with it.
Pilou wrote:
> How this sort of thing will be integrated to the next version?
> As native function or as Shortkey of plugin or...
Hi Pilou, I think as a plug-in just like this... It is not very practical for me to build every single thing as a "native" option, especially adding too many things to the default UI can cause problems.
It works well to put some interesting but less frequently used type things like this as plug-ins instead - that lets you access the functionality if you want it but keeps the default UI more streamlined.
I do want to make it easier to install and use plug-ins, like for instance I want to make it possible to have a menu that shows all installed plug-ins so that you can run one by picking it off a menu instead of needing to set up a shortcut key for it like you currently do.
