>>>But unfortunately due to the nature of geometry, I have not been able to manually test every single combination of every single geometric shape combined together, there is just too much variation.
I thought the beta testers would of done most combinations.
>>>I'm not sure exactly what you expect for me to have done, I mean do you expect for me to have manually drawn every single possible rotational alignment between a cylinder and a sphere in my own testing?
Possibly 4, one in each view.
>>>The difference is that I tend to draw these in the 3D view
It is not always easy to use the 3d view for some construction.
>>>In fact, I'm a bit confused - have you run into the problem at all on your own, or just when you experimented with the specific example?
Yup, on the chess piece. I was having a number of problems attempting to boolean out sweep solids.
>>>During a beta release period it is a lot easier for me to slip in bug fixes more rapidly.... I think I've already explained this before.
But you say this is a problem with the library and not in your own code, so how could you fix this anyway?
>>>If you are unhappy with the quality of the product or with my release policy, then I can certainly refund your money if you would prefer to switch to a different product.
So I have to be completely happy and not question, or take a refund and go away?
-Steve
