Hidden line snapping
1471.1
There is an option to hide (view) line/edges, but snapping is still made to these.
I am not sure what you are adding to version 2, maybe layers which would allow better control, so at the moment, more of a question rather than a request/wish.
I know I can hide other objects, but I find the behavior of that a little confusing at times, as sometimes the object I select will hide, and other times the object I select stays with other objects becoming hidden. If say I select object~hide, and the object hides, then I press hide again, then there is a reverse~ objects shown will hide/ objects hidden will show, but if I select to draw a line, then the hidden/shown objects reverse again.
Regards,
