| Hi Steve,
 > Just wondering if there a way (maybe script) to check an object
 > for open/closed polysurf (solid or not).
 There isn't a way to do it right now, but it will be an easy thing to add for V2.
 For MoI v1 you need to copy/paste into Rhino for this checking.
 There is a script method for finding closed curves or not, it just happens that nobody asked for the equivalent for surfaces until now.
 > Also, can I get any info on an object (location / orientation etc)
 If you just want to get an idea of the coordinates, you can run a drawing command (for example line), and look at the x,y,z coordinates in the bottom toolbar when you snap on to a spot on the object.
 For v2 it is planned to have an object properties panel that will make it easier to get various kinds of object information like this.
