windmill wing how to
1434.2 In reply to 1434.1
Hi Chuck, can you please post the .3dm model file with your rectangle and ellipses in it?
It will be a lot easier to understand what you are trying to do by looking at that model file instead of from your text description alone.
Also if you have any kind of rudimentary 2d sketch drawing of what you want the wing to look like, it would also help a lot if you could post that as well.
Otherwise, my best guess is that you would want to select all the ellipses, then run the Construct / Loft command to create a surface that passes through them.
