Wrinkles in 3ds exports?
1392.3 In reply to 1392.2
I did some test with the same model.
-The 3ds file looks the same in other apps, so it is not a SketchUp import problem.
-I exported with fewer polygons, and the problem becomes worse.
-I exported the same model from MoI as *.obj quads, and then imported to Rhino, and then exported it as 3ds. (SU doesn’t import obj). This 3ds file looks clean in SketchUp.
-I have seen similar wrinkles before in models I exported as 3ds from MoI, and some were small objects, so it is probably not just a scale issue.
Sheik
