Change color and thickness of lines?
1358.2 In reply to 1358.1
Hi Ed, this is possible, but you have to use notepad to edit the moi.ini configuration file to adjust these particular settings right now.
If you're running on XP, you will find moi.ini here:
c:\Documents and Settings\ [your login name] \Application Data\Moi\moi.ini
Make sure you close down MoI before editing the moi.ini file.
The settings that you are asking for are under the [View] section:
[View]
LineUnselectedColor=0,0,0
LineSelectedColor=255,255,32
SurfaceUnselectedColor=255,255,255
SurfaceUnselectedTransitionColor=255,255,208
SurfaceSelectedTransitionColor=255,255,128
SurfaceSelectedColor=239,239,0
TextColor=51,51,51
LineWidth=1
The colors are given as red,green,blue color values.
The ones that are labeled "Transition" are the colors used when you hover over top of an object before you click on it.
Hopefully that should do the trick for you, let me know if you have any questions,
