Open the save menu need a long time (large model problem)
1351.4 In reply to 1351.3
Hi Micha,
>>Also I wish, the mesher could show more options, most I miss:
>>* max edge length
I think you can do this by setting an angle in such a way that it results in a very low-poly mesh (it means the angle value like 180 degree). Then setting a "Divide larger than" option controls maximum polygon edge length. Moreover, you can apply this option to curved surfaces, planes or both of them.
>>* max distance edge surface (max error)
It has already been added to the wishlist.
Petr
