MoI 1.0 is released!
1284.40 In reply to 1284.37
> Hi Michael, Now that there is a licence key issue, is it still possible to run MoI
> from USB or other portable external storage device? -Petr
Hi Petr, this is still possible.
After you fill in your license key the first time, MoI will create a file that stores it, named "moi_v1_license.key". This file is located along side the moi.ini file, which on XP is stored under:
C:\Documents and Settings\ [your login name] \Application Data\Moi
On Vista on Win7 look under here:
C:\Users\[your user name]\AppData\Roaming\Moi\
If you copy that moi_v1_license.key file into the same folder as moi.exe on your USB stick, it will find it there when it starts up and you won't have to enter your key again.
You should also copy your moi.ini file over to the same place as moi.exe, so that you can bring your settings with you as well.
So with those 2 files copied over, your copy of MoI will be fully portable and you can take it along with you.
This is one of the cool features of MoI - most software these days does not allow you to do this!
Please let me know if you run into any problems with running in this way.
EDITED: 24 Nov 2010 by MICHAEL GIBSON
