Moi and Cinema 4D
1269.14 In reply to 1269.3
"Tweener" curves can be achieved using the "sweep" command with 2 rails and 2 profiles. see in this example image:
1) the 2 source curves to be "tweened"
2) draw 2 line segments, snapping to the midpoint of distance bewtween the ends of each curve
3) use the Sweep command, selecting the 2 curves as the rails, and the two lines as the profiles.
4) Select the edge of the surface, and Copy/Paste to extract the tweener curve.
jonah
