Custom distance script will not work
1231.2 In reply to 1231.1
Hi Rudy,
>>Somehow, when I open MOI, press ALT+D, nothing will happen. The custom distance will not come up.
Make sure, the shortcut Alt+D exists! Open options dialog window; in the Shortcut keys section there should be:
   Alt+D     CustomDistance
or you can set up the different shortcut if you want.
When you unzip a custom command into the command folder, the shortcut isn't created automatically for this new command. You must set it up manually first.
Petr
