> Yes, you can request any type of segmentation—for example, every 30 cm—or
> divide the whole or specific parts into any number of sections you’d like!
In general with NURBS modeling it usually does not help to increase the density of cross sections.
Most often the result of that is that undulations get compressed and become more visually prominent.
The kind of segmentation that you would want is one that follows shaping features instead of only being sampled in world axis directional slices.
Shaping features are something like this - areas of the model that have a distinctly lower radius of curvature within a localized region are where you want a fillet or blend transition between 2 separate patches:
You can then get a good idea of the patch boundaries. But not all of the boundaries are necessarily going to be a "natural edge" of the underlying surface, some will be formed by making extended areas that are then trimmed.
This is a quite advanced and difficult type of NURBS modeling to do, it's a lot easier to do it with subd surfaces where there is no extension or trimming you just need to manage a lot of small elements instead but locally smooth blending is also automatic with subd.
The area where NURBS modeling is strongest is when much of the model is accurately described by 2D drawings like with mechanical parts.
