Moi3D & Free Ai without any MCP !
12142.44 In reply to 12142.41
> I think the parts of the car are these slices of varying widths, from front to back!
That's unfortunate because it generally isn't feasible to construct a complex shape with a lot of localized detail like a car body just with one single surface lofting through cross sections.
With complex forms like a vehicle body it needs to be made up of multiple NURBS surfaces, not just one single surface and many of the surfaces should be larger extended shapes that are trimmed.
If you want to produce a model using data that is basically the same as a 3D scanner point cloud then generating a sub-d polygon mesh model is a better approach.
> The goal was to see whether it was possible to obtain surfaces—or, better yet, volumes inside
> Moi3D—generated by the machine based on a sketch!
The answer looks like "No" since I haven't seen anything but very poor quality surfaces posted so far.
