Moi3D & Free Ai without any MCP !
@ Michael
Yes, you can request any type of segmentation—for example, every 30 cm—or divide the whole or specific parts into any number of sections you’d like!
For instance, here it’s split into two horizontal sections to adjust how things look around the door area.
Seems The eggs got burnt. (@ Paq ;)
You can rename all the curves in all the sections at any time—they remain organized from the very start!
A short tutorial on how to replace the analysis of curves and the "Zebra" function inside Moi3D.
To compensate for this—both when generating the curves mathematically and when inspecting them visually in MoI3D—here is how you can approach it:
1. On the Curve Side (NURBS Generation and "Cleanliness")
Fewer control points and clean continuity: in NURBS, a "clean" curve (visually taut, without hidden waves) often comes from a cubic degree (M = 3) with a minimal number of well-placed points rather than lots of closely spaced points that introduce micro-inflections.
Smooth progression of coordinates (X, Y, Z): when a curve is built numerically, we check monotonicity and spacing consistency between points (no sudden jumps or unintended back-and-forth) so the derivative stays smooth.
Visual check in MoI3D: even without curvature combs, turning on control points (Show points / EditPtOn) is very revealing: if the control point alignment zigzags instead of flowing smoothly, any surface built from it may ripple.
2. On the Surface Side (Working Around the Lack of Zebra in MoI3D)
Parallel lines / control grids: in MoI3D, you can project or trace a set of parallel curves (or isoparms / cross-sections) onto a surface and watch how evenly spaced and smooth their curvature is—acting somewhat like a quick continuity check.
Blend rather than raw joins: whenever you connect two patches (such as the side flank and a recess or crease), using Blend set to curvature (G2 / curvature when the geometry allows) helps avoid harsh breaks in highlights.
EDITED: 26 Nov by PILOU
