Moi3D & Free Ai without any MCP !
12142.35 In reply to 12142.34
<< What aera...
All cuves of each part must be surfacing between them by user!
For this part
<< For example which commands does it indicate to be used to construct this indented area:
That recessed / sculpted lower-door area—right above the rocker panel between the wheel arches—is a classic automotive design cue to visually lighten the flank and guide airflow.
In MoI3D (working in 1 unit = 1 meter inside your .3dm file), the cleanest way to avoid ripples or pinch marks is to start with a broad, taut flank surface, then cut and blend rather than trying to fold everything into a single patch:
Recommended Workflow in MoI3D
1 Build a clean, taut flank surface first
Create a smooth, continuous side surface (between the rocker/sill line and the beltline/shoulder) using Loft or Sweep1 over NURBS curves with sparse control points (Show pts to check even spacing).
Keep a backup copy of this surface or your curves before cutting.
2 Define the recess boundary
Draw a closed curve or project one onto the flank with Project to shape the elongated almond/teardrop pocket along the lower door.
3 Cut the opening
Select the flank surface and run Trim with your boundary curve to open the pocket.5
This leaves a clean outer body surface with a crisp boundary edge.
4 Create the recessed backing (Offset or Loft / Sweep1)
For the recessed/dark inner backing, use Offset inward (toward the vehicle centerline Y) to set the pocket depth, or build a smooth backing surface (slightly angled or sculpted) with Loft or Sweep1.
5 Connect the outer edge to the recessed backing with Blend
This is the key step for a smooth automotive transition: select the trimmed flank edge and the corresponding edge on the recessed surface, then run Blend.
Tune the bulge / tension (and continuity such as G1 or G2 depending on the look you want) to get that gradual, crease-free transition.
6 Finish seams and detailsIf the rocker sill or door shutline crosses the pocket, apply Trim or Split at the end, then Fillet any sharp edges where needed.
Curves added for designing and surfacing the complete door (Green)
Extension of the 3 longitudinal rails to the front of the door (X = 1.40 m):
Upper belt line (Z ≈ 0.75 to 0.88 m);
Mid-flank feature line (Z ≈ 0.55 to 0.64 m);
Lower rocker/sill line (Z ≈ 0.175 to 0.24 m), running continuously from the rear to the front of the door.
Two vertical door pillars/cutouts (X ≈ 2.65 m at the rear and X ≈ 1.40–1.45 m at the front): these close the complete door frame around the recessed area (X ≈ 1.75 to 2.58 m), allowing you to generate a clean "Loft" or "Network" surface across the entire door panel before performing the "Trim" and "Blend" operations for the recess.
Here is a simple, clean workflow for transitioning from these curves to a refined, crease-free door surface:
1. Generate the door surface before cutting
Select the door’s cross-sectional profiles (the two vertical front and rear cutouts, plus an intermediate section if necessary) and use the "Loft" command, referencing the green longitudinal rails (beltline, mid-body character line, and rocker panel) to maintain a taut, well-defined curvature.
2. Cut out the recess opening
Use the "Trim" command on the door surface, guided by the cyan outer loop (X ≈ 1.75 to 2.58 m, Z ≈ 0.25 to 0.44 m), to create the opening for the recess.
3. Create the recessed base and the transition
Construct the back wall of the recess using the magenta loop (Y ≈ ±0.81 to ±0.82 m), then connect the trimmed edge of the door to this base using the "Blend" command. Use the central red curve as a visual guide, and adjust the tension and continuity (G1 or G2) to ensure a smooth surface without ripples or undulations.
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/concept_aero_porte_complete_moi3d.igs
EDITED: 25 Nov by PILOU
