Moi3D & Free Ai without any MCP !
12142.31 In reply to 12142.30
<< About Wheels: perspective problem absolute Z temporary resolved by a proposition.
But we can ask to put any new measures
<< Regarding the open curve on the lower part of the door
This is part of the recess shown in the sketch who must asked to modify! :)
<<About the pinky diffusers forms
What are diffusers used for?
The primary role of a rear diffuser is to manage airflow beneath the car, generating aerodynamic downforce while limiting drag (resistance to forward motion):
Accelerating air under the floor: beneath a car, air becomes compressed and slowed down between the chassis and the ground. A flat underbody and well-contoured tunnels promote faster, more consistent airflow, creating a low-pressure zone (ground effect) that presses the car against the tarmac.
Slowing and smoothing the airflow at the exit: at the rear, upward-sloping ramps and tunnels—in this case, three at the tail—allow the high-speed air from beneath the car to rise gradually and expand, avoiding abrupt separation or the formation of large, suction-inducing vortices behind the vehicle.
Channeling and guiding the flow: longitudinal fins (or "strakes") prevent air from higher-pressure areas on the sides from spilling into the low-pressure zones within the tunnels, thereby stabilizing downforce during cornering and at high speeds.
In this concept model, the three tunnels—two on the sides, housing the exhaust outlets, and one central tunnel beneath the license plate—provide both a highly distinctive visual signature and a coherent architecture for underbody airflow extraction.
About the process
you can ask any schemas
and Question / Answer about the drawing curves... part by part or not...
Along with the latest batch of curves, we’re essentially receiving a tutorial on which Moi3D functions to use!
As it's only curves ... if surfaces asked it's like thinly sliced ​​ham (chiffonade) :)
So not very practical, to say the least!
We’ll likely have to wait two or three years for this process to improve—to the point where 3D nurbs volumes can be designed directly!
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/concept_aero_arche_haute_raccord_moi3d.zip
EDITED: 25 Nov 7:37 by PILOU
