Moi3D & Free Ai without any MCP !
12142.28 In reply to 12142.27
It seems I simply hadn't asked for enough curves!
And that, to avoid polylines, all I had to do was ask for smooth NURBS!
There is no name here but no problem to add them after because
The 56 curves were generated in a specific order, grouped by color and geometric function (axes, fenders/flanks, roof/glazing/rear oval, wheel arches, cross-sections, and finally the tail/diffuser/fins), which makes it very easy to assign them clear and consistent names, should you wish to do so later.
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/56_courbes.3dm
And no problem to change any form!
(for example: a more elongated or more compact oval, a more triangular/tapered shape, a more steeply raked rear window, or a hood/glazing arrangement that conforms more closely to the rear deck and trailing edge). The relevant curves (and/or the entire wireframe) can then be regenerated while maintaining continuous NURBS curves defined by control points.
EDITED: 24 Nov by PILOU
