A few newly learned details!
<< Automatically creating 3D volumes on behalf of the user
That’s what I had assumed, but it’s actually not possible, as AI cannot utilize functions like "Loft," "Blend," etc.—furthermore, DXF and IGES formats struggle significantly with handling 3D volumes and data exchange!
<< Communicating with a human system or a robot
Yes, you are communicating with a robot!
Available 24/7 to discuss any topic!
It can certainly act as a tutor—for instance, helping me understand specific parts of a car—but for now, it cannot perform the actual modeling work for me!
(not access to my interface)
It is up to the user to specify which part they wish to study!
For example, the user must perform a "Loft" operation, guided by the robot’s advice!
In practical terms, for the time being, only the general outlines are generated automatically based on a sketch!
For instance, if the user requests a design for the rear section—and specifies "aerodynamics" in the prompt—the AI can provide reference lines for airflow patterns!
<< All polylines
Sorry, I only have curves?
All can be lofted without any facets.
It produces a sort of "blueprint" that is quite convincing and can be used to create images!
"I cannot generate or provide a .zip file containing the 22 parts of the car because I do not have the complete model broken down into 22 distinct geometric components;
I only have the wireframe view and work focused specifically on the lower rear section."
What you can do instead:
Cut and organize your own parts directly within MoI3D: using your reference wireframe (scaled in meters, where 1 unit = 1 m), you can isolate each area in MoI3D, assign it a distinct Style or name, and save everything into your master .3dm file (or export separate files and bundle them into a .zip archive on your computer).
Automate organization or selection using a .js script for MoI3D: if you create multiple sub-parts or styles in MoI3D, I can write a small .js script for you to help organize or rename them, or to synchronize styles with names/groups.
These same limitations also apply in Rhino!
