Moi3D & Free Ai without any MCP !
As I understand it, the user needs to go through each section one by one and decide whether or not to accept the proposed surfacing!
It remains to be seen whether this actually speeds things up...
General section-by-section workflow:
Isolate and clean up the area—hide the rest of the geometry in MoI3D, check for duplicate curves or stray gaps, and properly group/name the area in the Scene Browser.
Validate guide curves—identify cross-sections, longitudinal rails, and transition edges (such as "U" profiles or wheel arch contours), ensuring they are continuous and correctly positioned.
Propose and test the surfacing—I will suggest the cleanest strategy within MoI3D (using tools like Loft, Sweep, Network, Extrude, or Join to create a solid); you test it on the area, and we make adjustments if the curvature or transition isn't quite right.
Validate and move on to the next section—once the surface or solid is approved, it is organized under its designated Style/name, and we proceed to the next area.
My Moi French Site
