MoI3D on Fedora 44 with FVWM/Xorg quirks
12134.1
Hi!
Just in case you are one of the very few people on this planet still using FVWM (best WM ever, IMHO), this is what I needed to get MoI3D working nicely on Fedora 44:
Issue: In split view, the "Area/Zoom/Pan/Reset" field caused a black rectangle when moving the mouse pointer from one view to another.
Fix: install "picom" (Xorg compositor) using "sudo dnf install picom" and make sure it gets executed in ".xsession", i.e. "picom --backend egl &".
If you are using xsetroot to set you background color, then you need to replace that with hsetroot (sudo dfn install hsetroot).
Issue: mouse input events lagging behind. I.e. when zooming in by mouse wheel scroll, then the last zoom-in step is not carried out.
When then zooming out (using the mouse wheel), then there is one more zoom-in operation before a zoom out happens.
Fix: start Moi3D with the following command line: env vblank_mode=0 wine MoI.exe
BTW.: an alternative solution is to install the Lutris game launcher and add MoI3D as a game.
Similar to Steam/Proton, Lutris allows the user to select older wine versions that make MoI3D work without the above tweaks.
best regards
Bernhard
