Scripts installation
12126.40 In reply to 12126.39
Hi Mala,
> What is missing now is the other GUI with the ribbon at the bottom.
> This is presumably because I deleted the CustomUI.2.0.beta2 script?!
The other GUI is created by files in the startup folder.
If those are missing it means you accidentally deleted the startup folder, is it empty now?
To set it up again you need to copy the files from the startup folder inside CustomUI.2.0.beta2.zip into %AppData%\Moi\startup .
Maybe it would be better for you to contact me through e-mail to help you get set up instead of here on the forum. It will probably be easier if we do things just one small step at a time.
My e-mail is: moi@moi3d.com
