Hi Mala,
> This the list of scripts I found and put into the command folder.
It should be "commands" (note "s" at the end), not command.
You need to put the contents of all those folders into the commands folder.
Most of those will have 2 files, one with a .js file extension and one with .htm file extension. Those 2 files need to get copied into the appdata commands folder. Directly into that folder, not into a child folder like you currently have.
