Scripts installation
12126.17 In reply to 12126.14
Hi Mala,
> When I launch MoI, I get the error message I’ve attached, and I still
> can't run the scripts within the program.
You will get that error message on the program startup if you have placed the _Voronoi.js file in the %AppData%\Moi\startup folder.
It is not intended to be used as a startup script, it is meant to be copied into the commands folder.
If you delete the _Voronoi.js file from the startup folder that error message should stop being shown on program startup.
If you have got _Voronoi.js and _Voronoi.htm copied into the commands folder, how are you trying to run the scripts?
