boat hull
12117.13 In reply to 12117.9
Hi wim, thanks for posting the file.
So for the blend method you can set up a cutting curve like this:
Use Trim or Boolean Difference to make an opening:
Select these 2 edges:
Run Construct > Blend to fill in the empty area with a smooth blend surface:
