Pipe_3 plugin W.I.P.
12107.1
Using the well-known "Pipe_2" plugin (for generating pipes along curves) as a base, I created a version better suited to my specific needs and requirements.
The plugin is still a bit rough around the edges, and I am continuing to refine it, but it is already fully functional.
If anyone is interested, let me know, and I’ll upload the files here.
Feedback and suggestions are welcome.
Demonstration of the plugin in action – at the link:
https://youtu.be/QTe_J5uWSv8?si=fkl18p7HA9IW9v4P
Description:
Creates a pipe along one or more curves and allows you to edit the path without exiting the command.
## Launch
Select curves → launch Pipe3 (or launch first, then select curves). The files `Pipe3_NN.js` and `Pipe3_NN.htm` are located in the MoI `commands` folder.
## Panel
- **Circle / Square / N-Side** — cross-section type. Circle: Diameter (toggles to Radius by clicking the label). Square: H. N-Side: Sides, Circum (size to face / to corner, same as the native Polygon command).
- **Thickness** — wall thickness; 0 or empty — solid pipe.
- **Update** — build/rebuild the pipe using current parameters and the curve.
- **Done** — accept. **Cancel** — remove the pipe and restore the original curve.
## Edit Curve — path editing
- `Move points` ☑ — points are visible on the curve.
- click and drag a point → moves it (along with all other selected points);
- click — select one; Ctrl+click — add/remove; click in empty space — deselect all;
- **Shift+drag**: curve end — moves strictly along its segment; corner — moves within the plane of its adjacent segments.
- The pipe rebuilds after every drag operation (`Hide pipe` ☑ — hides the pipe while editing).
- Fillets near a moved point rebuild automatically (maintaining the same radius).
## Segment — welded elbow
Open the tab → points become visible. Click on a corner (or the midpoint of a fillet) → **Segments** (number of straight sections, 1–10), **Radius** → **Apply**.
Applying with different values ​​modifies that specific corner. If the radius is larger than the original fillet, the elbow segments extend into the adjacent straight sections. ## Preview, Undo, and Commit
- Everything done within **Edit Curve** / **Segment** is a preview. **Update** commits the changes. Exiting the tool without using **Update** (e.g., by deselecting **Move points** or leaving the **Segment** tab) reverts the curve to its initial state.
- **Undo** (button / Ctrl+Z): inside the tool, it reverses one action at a time; outside the tool, it reverts through committed **Update** steps back to the original curve.
EDITED: 13 Sep by KRASS
Size: 27.3 KB, Downloaded: 4 times, Dimensions: 215x329px
