Object doesn't export cleanly in STP
12102.2 In reply to 12102.1
Hi Cuboctahedron, it may not like some slivery surfaces, see attached file.
What happens if before you export from Moi, select the object and run the ShrinkTrimmedSrf command (type the tab key, then type ShrinkTrimmedSrf then Enter?
I'll see if I can make a version with those slivers removed by mirroring the other half over.
