File Preview in MacOS
12093.2 In reply to 12093.1
Hi James, yes thumbnails in finder windows is supported in MoI v5.
Check that it hasn't been turned off in MOI under Options > Import/Export > 3DM options > "Write thumbnail preview image" checkbox.
Also you may need to enable the extension in macOS System Settings, under under General > "Login Items & Extensions". There should be an entry there for the v5 app and when you click the circle with an "i" in it there should be a switch that you can turn on.
